Can't slice
Posted: Thu Feb 02, 2017 5:22 am
by BigE
I tried clicking on the Slicer and I get the following error
Print Slicer Error.png (23.35 KiB) Viewed 20152 times
Windows 7 Enterprise Edition, 64 bit
Re: Can't slice
Posted: Fri Feb 10, 2017 3:44 pm
You can try installing easy print on other disks(not Disk C) to take a look.
Re: Can't slice
Posted: Sat Feb 11, 2017 4:02 am
by BigE
Yep. I'm going to install another hard drive in my computer just so that I can use a buggy slicer. :roll:
Re: Can't slice
Posted: Wed Feb 15, 2017 9:41 pm
by dart16
Already been stated on this forum that you need admin privileges to write to c:\program files(x86). What is needed is config files to be written to the users documents folder.....
Re: Can't slice
Posted: Thu Feb 16, 2017 3:37 pm
by bang
Indeed it should be...
Re: Can't slice
Posted: Thu Nov 09, 2017 3:34 am
by Chema57
I also can´t slice. I tried clicking on the Slicer and I get the following error:
I could not find the generated G-code file.
-the slicer had an error an didn´t finish slicing. Check log out put.
-the slicer stores the file with an unexpected filename.
Expected Filename and Location
C:\Users\Chema\AppData\Roaming\easyprint\work\composition.gcode
At first time y could slice without problem more than four files but now is impossible
Re: Can't slice
Posted: Thu Nov 09, 2017 9:37 am
Is there any hint of the error code?Search on Google maybe help you.
