Works wrong I guess
Posted: Wed Mar 29, 2017 12:37 am
by indy
Hi. Can somebody help me ?
It seems something is wrong because when I try to Auto Home it goes to wrong side I guess what makes not good noise.
Check some video: https://www.dropbox.com/s/i79605yp7ihin ... 1.mp4?dl=0
What could be problem ?
Re: Works wrong I guess
Posted: Fri Mar 31, 2017 7:44 am
by Newopint95
you need to reverse the direction of your X and Y motors.
Posted: Fri Mar 31, 2017 8:19 pm
by indy
Newopint95 wrote:you need to reverse the direction of your X and Y motors.
Hmm thanks did not knew you can do that. Going to check settings where can I do that :)
Posted: Fri Mar 31, 2017 8:46 pm
by indy
Can not find anything in settings.
As I read about similar problems there were some suggestions to change wires for motors, but thats not possible in my case. It does not go in if around.
Some said it should be changed in firmware but I'm not sure where and how.
Any suggestions ?
Posted: Sun Apr 02, 2017 11:45 pm
by indy
Found that it should be done in firmware, so I found that and updated my motor directions. Now this works fine.
