z-axis feed ajustment
Posted: Fri May 19, 2017 2:33 am
				I have an older ME Creator (not the version 2)
I want to replace the M8 threaded rod with an actual 8mm feed screw.
To do this I will have to adjust something for the pitch from what I believe is 1mm per rotation to the new 2mm per rotation.
Where would this be changed? I was assuming it would be in the software when I ordered the feed screw.
As I search around I am finding I may have to learn how to do the adjustment in the printer firmware itself?
I am not a programmer...
thanx in advance
thanx in advance
