want to install Firmware to increase working temperatures of my e3DV6
Use Arduino 1.8.2 on Linux
and the precheck of the firmware I downloaded from Geeetech creates this error :
Code: Select all
Arduino: 1.8.2 (Linux), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch/Marlin.h:23:0,
from sketch/BlinkM.cpp:5:
sketch/pins.h:2956:0: warning: "X_MAX_PIN" redefined
#define X_MAX_PIN -1
sketch/pins.h:1363:0: note: this is the location of the previous definition
#define X_MAX_PIN 24
sketch/pins.h:2957:0: warning: "Y_MAX_PIN" redefined
#define Y_MAX_PIN -1
sketch/pins.h:1369:0: note: this is the location of the previous definition
#define Y_MAX_PIN 28
sketch/pins.h:2958:0: warning: "Z_MAX_PIN" redefined
#define Z_MAX_PIN -1
sketch/pins.h:1375:0: note: this is the location of the previous definition
#define Z_MAX_PIN 32
from sketch/ConfigurationStore.cpp:1:
from sketch/thermistortables.h:4,
from sketch/Configuration.h:792,
from /home/knief/Dropbox/Shed/Prusa I3/Marlin-PI3_Pro_B/Marlin/Marlin.ino:33:
from sketch/MarlinSerial.cpp:23:
from sketch/Marlin_main.cpp:30:
sketch/Marlin_main.cpp:2667:36: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
In file included from sketch/SdFile.h:27:0,
from sketch/cardreader.h:8,
from sketch/Marlin_main.cpp:44:
struct fpos_t {
In file included from sketch/Marlin.h:10:0,
/home/knief/arduino-1.8.2/hardware/tools/avr/avr/include/stdio.h:950:33: note: 'fpos_t' has a previous declaration here
exit status 1
using typedef-name 'fpos_t' after 'struct'"Show verbose output during compilation"
Who can help please ?
