Max Temp Errors - MeCreator 2-fixed
Posted: Mon Jul 10, 2017 1:38 am
				MeCreator 2
This thing has been working just fine but now I'm getting continuous 'ERR: MAX TEMP' errors as if there is no temperature control at all.
Any suggestions on what to look for? The numbers in the software are fine, the upgraded firmware v1.0.2 has the correct numbers for shutting down the heaters but it still overheats. In addition, the temperature oscillations are wild, going from about 225 to 298 degrees, back and forth and never settling down to the 250C that I've chosen to print ABS. I've done the PID tuning several times but it appears this is making no difference.
Suggestions?
thanks,
tony
Suggestions?
thanks,
tony
