I wanted to know if there was g-code to control the mix proportion of two different filaments. I am wanting to do many proportions and manually changing the ratio on the printer display panel is very tedious in this case.
If there isn't code, how can I at least store the last mix proportion setting? It seems that when I load a new print file that the mix ratio automatically changes so that only one filament extrudes.
Also, I have a Prusa i3 M201 with the GTM32 Pro B board and 2-in-1 hotend extruder.
Thank you!
						Mixer G-code
Re: Mixer G-code
Maybe you could save the config you use last time and apply it to the next time you print.
