Hello All,
I just got my A30 and this is my first 3D printer with bowden tube setup. I am not sure what is going on and would like some recommendations.
I've been able to print a lot of test pieces and the printer was doing well. Then the bowden motor start skipping and pla started to extrude less. So I removed the filament and tried again and it seemed to work. Later I started having the same issue and this time I decided to raise the temperature from 210 to 215 and that seemed to work. On the next print I had to raise the temperature to 220 or the feeder mechanism would start skipping again. Finally, On my next print I had to set the temperature from 220 to 225. I keep having this problem and not sure if there is a sensor that is wrong or some other electronic piece or if the hotend is clogged. If I wait a little I can manually push the filament through but and it flows well but then feels like it gets hard to push and stops- like the filament is not melted yet.
Any ideas?
Sincerely
Serp
I need to keep increasing HotEnd Temp
SerpentWarrior
Return to “Geeetech A30 Series”
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
