TMC 2130 help
Posted: Fri Sep 28, 2018 4:33 am
				So to start out I'm running a gt2560 for the main board and trying to use a pc power supply for the power. I've taken on adding TMC 2130's for the X,Y,and Z (don't know if the z is possible but it would be awesome to have it on there). After hooking everything up, temp sensor, heated bed, ext 1, all motor connectors, I uploaded the Marlin firmware and on initial start up extruder 2 led lit up (voltmeter shows 12v being supplied) with nothing connected. I look at the firmware and nothing shows that a second extruder is enabled.
Then it all gets a tad bit weirder when I look at my repetier-host and it shows that both the hotend and bed temp are 175c. And I can't get any movement from any axis.
Any help on this would make me extremely grateful.
