DOA
Posted: Wed Oct 17, 2018 8:35 am
by Strifexz
Hi Everyone.
Just got and put together my A10 today. Put it all together, and no power to anything. No Fans spin, lcd stays black, nothing but sad sad silence.
Am I missing something simple? Everything looks plugged into the board correctly, but I cant get the fan to spin even when I plug in the USB.
Re: DOA
Posted: Wed Oct 17, 2018 8:34 pm
by gdachs
Strifexz wrote: Wed Oct 17, 2018 8:35 am
Check that the PSU delivers 24V.
Of course not, the USB input gets 5V and the fans need 24V. That is the reason why the fans are not connected to USB.
Gerald
Re: DOA
Posted: Thu Oct 18, 2018 12:22 am
by Strifexz
Hi Gerald
I thought I would at least get the screen powered on when plugged in USB (Did on my tevo tarantula). I will grab my multi-meter and have a test when I get home.
Thanks for the reply.
Re: DOA
Posted: Thu Oct 18, 2018 6:03 pm
by Gingko
Agree, check the output voltage of PSU first.
Re: DOA
Posted: Thu Oct 18, 2018 11:33 pm
by DieLaughin
Do you get the power light on the switch illuminate when plugged in and turned on?
If not then start with the PSU as Gerald suggests. but if no light then either the mains cable/plug not delivering the juice or fuse issue at source.
If you get no life, then it looks like a return job for the PSU being faulty. New kit PSU should not be pulled apart as it has a warranty seal.
Re: DOA
Posted: Fri Oct 19, 2018 2:06 am
by Strifexz
Hi Guys
I do get the red light on when turning on the PSU. But no PSU fan.
Does anyone have an A10 and could check if the mainboard lights up when plugged into USB?
Re: DOA
Posted: Sat Oct 20, 2018 7:04 pm
by theklaus
Have you selected to correct voltage in the PSU (e.g. 230V in Europe)? There is a small rectangle hole on one side of the PSU where you switch the voltage with a iron clip or screw driver. But disconnect the power cable before you switch it.
Re: DOA
Posted: Fri Oct 26, 2018 12:09 am
by Strifexz
Yessir I did.
Sorry I should have posted it, the PSU was DOA. I got another one off Amazon and had Gearbest refund me for the $30 I spent on the new PSU.
Just to clear up a few misconceptions I had with the printer.
1. The LCD will NOT load up if plugged in through USB and no PSU.
2. The fans will NOT spin if plugged in though USB and no PSU.
3. The PSU fan WILL spin when the printer has power.
I had a Tevo Tarantula before my a10, and it would power up and spin fans through USB power. So I wasn't sure if it was a PSU or mainboard issue.
Hope this helps other people if they have the same questions.
Re: DOA
Posted: Sat Oct 27, 2018 4:21 am
by gdachs
Strifexz wrote: Fri Oct 26, 2018 12:09 am
As I told already, this is not a misconception! The 5V from the USB are not enough to spin the fans, so they are even not connected to the 5V rail.
