knob of LCD not working
I assembled and tested print using SD card.  Then the knob stopped working.  I can onlypush in.  But when I turn the know to change settings, it didn't do anything.  How to make to work again.
						Re: knob of LCD not working
I think you should remove the knob off then move it with your hand.
Maybe the knob inside loose.
I just assembled my brand newA10 and it also has a knob that will click but not move the selection when turned.
Hi,Daniel D wrote: Fri Apr 12, 2019 1:16 am I just assembled my brand newA10 and it also has a knob that will click but not move the selection when turned.
You can try to refer to this link then print a new knob for the LCD:
https://www.thingiverse.com/thing:618477
				ThePurplePig
I have the same problem, there's nothing wrong with the plastic knob, it is the potentiometer part that is not registering the rotation steps.
Is it possible to get a replacement part or PCB?
Still waiting from response from sales@geeetech.com after being sent to them by technical@geeetech.com. Been 2 months now.
The issue is just the pot, not the knob, itself.
Since it uses the flat ribbon without pins, sort of rules out just replacing the display and I didn't buy the thing to spend another $55 for new display & board. Time to spend my money on a different brand, I guess.
Hi, I am sorry about this, where did you buy it?
If it is an agent, you need to contact yourself.
If you buy here, please provide your order number and email address.
I have the same problem now. I've had my A10 since fathers day this year. I pretty much only print by USB since I'm not really a power printer. Just yesterday my knob doesn't register turns any more only clicks. Does anyone have an easy/quick solution?
Hi, If your screen knobs don't work,
You can contact your sales to replace it.
If you buy from an agent, you will need to contact yourself;
If you purchase from here, please provide your specific purchase address
and order number and email address.
We will help you.
We will help you.
I bought it off Amazon and its not even 3 months old.
