Dead Geeetech A10 :(
abssalom
Post by abssalom »
2 weeks after buy it, i was changing my geeetech a10 nozzle when suddently it stopped working. Control board doesnt seem to power up and i have no idea of what to do :cry: there are one red light in control board and one green light in power supply but nothing seems to work.
I was so happy with it and then that... :cry: :cry:
abssalom
Re: Dead Geeetech A10 :(
Post by abssalom »
No and no. The screen is totally off and the printer doesnt do anything if you connect to the PC. When i powered up before the fan of the control board immediately start to work and the screen lighted up, but now nothing happens except that light.
abssalom
Post by abssalom »
Apparently the 10a fuse (which links with the printer itself while the other links only with the hot bed) is dead, I have disassembled the hot end to see what happened and i have realized that the two cables that power up the hot end are quite exposed, when I was changing the nozzle, I had to short-circuit them with the adjustable wrench I use to hold the heather block... Is it normal for those wires to be this exposed? :|
I have ordered a few 10a fuses to change it and i will try to take care when i change my nozzles.
Regards.
We will keep an eye on it.
msi_msi2002
Post by msi_msi2002 »
Dear I had same issue
your power supply volt is very low not 24V
so no fans are working
Check power supply outlet volt
if so ask supplier to replace or buy a new one
abssalom
Post by abssalom »
msi_msi2002 wrote: Tue Mar 12, 2019 6:05 pm Dear I had same issue
WUT I dont understand you at all.
I have the stock power supply wich i think is more than enough to power the printer. The problem is that i caused a short-circuit by accident and the 10a fuse broke, that's it. I have replaced it and everyting works prefectly.
Nonetheless I honestly think that Heather Cartridge's wires are quite exposed, a simple touch with my wrench caused this....
