problem velocity extruder E1 on A10M
prof2meca
Post by prof2meca »
Sorry for my poor English, i am french :roll:
I have bought a A10M 3D printer, and i had te replace the motherboard
I just want to print with the extruder E0, and it turn very very fast !!!!! The extruder E0 works perfectly. I tried to switch the cable of extruder E1 on extruder E0, and i have the same thing. If i plug the extruder E1 motor of the output E0 it is ok ….
I had checked voltage of stepper and every thing is ok
If i try to miw, and i adjust the percentage of Extruder E1, the Velocity change
I would like to know if there is a probleme with the card or i have to modify a parameter
Help me pleaseeeeeeeeeeeeeeeeeeeee :?:
prof2meca
Re: problem velocity extruder E1 on A10M
Post by prof2meca »
i tried to swap 3 times but at each times the extruder E1 turn very quicly
prof2meca
Post by prof2meca »
I finaly find the solution :
Under the stepper there are connectors and there are 3 jumpers. On my board Nothing …
Now the extruder works perfectly
Thanks for your reply
