I just bought the geetech A10 3d printer and I'm pretty new to this, but I have some problem printing.
I did the test dog and it comes out well. I printed also two other stuff and everything was ok.
Then it started to drag the object on the plate. I thought about a problem with the extruder, so I cleaned everything until the PLA come out well and clean.
I re-adjusted the corner's level and started to print again. After a while (about the 5%) the extruder started to drag the PLA, I cleaned everything, tried again and happens again
As you can see the base is a bit detached from the plate, but only by one side, what's wrong? The plate is too hot and deformed the PLA?
