A10M control board fan not starting
ilovedoom
Post by ilovedoom »
After the first test print from the SD card I saw the control board fan is not starting on the A10M. I have near an A10 and its fan start as the printer is turned on.
I disassembled the top of the control box and the fan has no visible issues or smell. then I unplugged and plugged back to check for bad connection.
After the print I'm doing on the A10 I will swap the fan in order to check on another board.
Can anyone suggest something to do to solve the issue?
Re: A10M control board fan not starting
I suggest you use the multimeter to check the fan port voltage.
If you can get the voltage then it means the cooling fan broken.
If you can't get the voltage then it means the motherboard somewhere has a broken part.
ilovedoom
Post by ilovedoom »
I have a multimeter but i'm not able to reach the plug, it is in a corner under a nut. any suggestion?
ilovedoom wrote: Fri Apr 12, 2019 6:06 am I have a multimeter but i'm not able to reach the plug, it is in a corner under a nut. any suggestion?
You can attach the photos.
We don't know which part you are talking about.
