Good afternoon. I am a user of an a10m and I have a serious problem with the x axis. When the y-axis is at a height of 50mm the x-axis motor has a malfunction, below that height it works perfectly.
https://www.youtube.com/watch?v=Wt8XcXsnHoo
I have tried to do the following tests to rule out problems and the results are always the same:
- Change of motor x by y.
- Change of motor cables x per y.
- Change of connectors on base plate of x by y.
- Change of motor drivers x by y.
On the other hand, I have disassembled the x-axis motor, and holding it with my hand I tried to put it at different heights. The result has been the same, when I raise the engine to a certain height, it starts to fail.
It seems supernatural ...
a10m x-axys problem
Re: a10m x-axys problem
It seems the motherboard has an issue.
Sometimes the PSU has the issue will cause it also,if you have a spare PSU then you can try it
