Printer just dont want to start :(
Posted: Tue Apr 16, 2019 7:12 pm
by mongini12
Hi guys.
my A10 arrived and i've put it together
but the display wont turn on, and the printer wont be recognized by windows or Cura...
The Power Cable seems to be fine (both ends) and the display ribbon cable is placed exactly like on the mainboard (flat, blue facing away form PCB)
any ideas whats going on here?
Re: Printer just dont want to start :(
Posted: Tue Apr 16, 2019 7:15 pm
by mongini12
oh and i forgot to mention: the fan for the Mainboard doesnt spin at all when i switch on the PSU
Posted: Thu Apr 18, 2019 4:37 pm
I think you need to check the motherboard fuse is ok or burned.
You can use the multimeter to check it.
Posted: Fri Apr 26, 2019 2:59 am
by tech1962
funnily enough i have the same issue... it arrived yesterday.. assembled it today. nothing on the lcd display. power supply fan is spinning. forgot my multimeter so didn't check voltages yet. i can see red led on the main board. again nothing on windows or mac os. no motors moving. bought this as a test printer to see if it could be used by students...
any suggestions helpful.. bar hopefully not sending it back!
Posted: Fri Apr 26, 2019 9:13 am
Posted: Sat Apr 27, 2019 1:24 am
by tech1962
in my case it was a short on the extruder/heater control board... blob on solder shorting 2 pins... desoldered.. desoldered.. all fine
Posted: Sat Apr 27, 2019 6:46 am
by pauldude000
If you are like me, you probably were in a hurry and forgot to switch the PSU from 220v to 110v (slide switch on side of power supply). Nothing at all works in the US until that switch is flicked, then printer fires right up, lol.
