WiFi box
Posted: Sun Apr 28, 2019 1:24 am
by Kinggeordie
Just a thought has any one tried connecting the box and printer to a small WiFi print server to work on windows 10 ?
Would the print server connect and assign a IP address for the WiFi module and e180 printer?
I have seen these on the net for around £30/$40
Re: WiFi box
Posted: Sun Apr 28, 2019 1:45 am
by _kaktus_
Hello.
3D WiFi module is a proprietary device developed in GT. To manage it, you need a GT application running on Android OS.
Re: WiFi box
Posted: Sun Apr 28, 2019 3:26 pm
by Kinggeordie
Work around to getting to control from a win 10 tablet/pc, download free software called blue stacks android emu, install easy print 3D within the emu, works great for me
Re: WiFi box
Posted: Sun Apr 28, 2019 4:49 pm
by _kaktus_
Re: WiFi box
Posted: Tue Jun 02, 2020 11:56 pm
by eduardofaccio30
Guys a question, do you have a PDF or some document where I be able to see blueprints of a wifi box? Because I was searching by
seo word on google to get some of these to print it but I still without find one. If someone of you can help me with this I'll be thankful
Re: WiFi box
Posted: Wed Oct 28, 2020 6:17 am
by Martin99
Es interesante trabajarlo en Android. Trabajo como encargado de una página web de
travestis en españa y todo el trabajo que realizo en la web lo puedo hacer con una WiFi Box sin ningún problema, la recomiendo.
Re: WiFi box
Posted: Sat Oct 31, 2020 2:03 pm
by lydiasna
Kinggeordie wrote: Sun Apr 28, 2019 3:26 pm
Wireless routers typically feature one or more network interface controllers supporting Fast Ethernet or Gigabit Ethernet ports integrated into the main system on a chip (SoC) around which the router is built. An Ethernet switch as described in IEEE 802.1Q may interconnect multiple ports. Some routers implement link aggregation through which two or more ports may be used together improving throughput and redundancy.
myaarpmedicare.com
Re: WiFi box
Posted: Sun Mar 20, 2022 1:07 pm
by ahmedhanif21
This is really helpful information that you have shared with me I was searching for the solution and found it on this platform I'm following you for more informative solutions like this.
Best Wireless Speakers
