3D Touch crashes into bed
Posted: Thu May 02, 2019 4:37 am
				Hi guys,
I've seen similar problems to this, but not a definitive solution, so here goes.
I've got an A10M and had the stock Marlin 1.1.8 in it, with Configuration.h modified to enable 3DTouch etc. It was all working fine, and bed levelling worked too (most of the time). Then it started crashing the nozzle into the bed sometimes, but not on the first probing (ie. right in the middle of the bed), where it worked fine, but always the second one at the front left of the bed. It goes down, the pin hits the bed and the light goes on (and the pin jumps up a bit), but the nozzle continues downwards and there is a nasty knocking noise as the motor can't go any further. Then the 3DTouch starts flashing, the nozzle goes up and I get a 'probing failed' on the LCD display.
I updated the firmware today to the very latest (9/1/19) because I saw a reference to 3DTouch issues, and now everything moves much slower, but still the first double probe in the centre of the bed is fine, but the second (front left) grinds into the bed.
What is going wrong ? It can't be the 3DTouch can it, since the first probing succeeds ?
