Hardened steel nozzle for A10M/A20M? Anyone tried them?
I'm looking to grab some hardened steel nozzles for my A20M, and I'm wondering if anyone's found one that works well with the A10M/A20M.
I found these, that look like they would fit: https://www.amazon.com/PrimaCreator-PC- ... op?ie=UTF8
But one of the reviews complained about excessive stringing (might be user error though)
Anyone tried these, or got any recommendations for other ones?
Re: Hardened steel nozzle for A10M/A20M? Anyone tried them?
Hi, The nozzle type of A20M is m7 thread, It is not the standard MK10 4mm inner diameter nozzle. You need to check it at first. The default inner diameter should be 2mm.
Well, but, Where we can buy M7 nozzle fo A10M, A20M?
I only find the default 0.4
Hi, you can search for the A20M nozzle used on the official website.
It says it is M7 threaded, though I'm not sure what MK10 means.William wrote: Fri Jun 21, 2019 9:18 am Hi, The nozzle type of A20M is m7 thread, It is not the standard MK10 4mm inner diameter nozzle. You need to check it at first. The default inner diameter should be 2mm.
I am also looking for different size nozzle (0.6) and stronger one, to print abrasive filament, unfortunatly I did not find any for now...
Also, I am wondering what would be the problem of using a 4mm inner diameter rather than 2mm ?
please GEEETECH!!!! we need to print more materials!!!! hardened nozzle now please!!!! is it so difficult??
i guess slowler color changing...DzzD wrote: Fri Nov 01, 2019 7:29 pm I am also looking for different size nozzle (0.6) and stronger one, to print abrasive filament, unfortunatly I did not find any for now...
Hi, the A20M uses M7 nozzle with a precision of 0.4mm.neich03 wrote: Thu Nov 14, 2019 12:53 am please GEEETECH!!!! we need to print more materials!!!! hardened nozzle now please!!!! is it so difficult??
The issue is that Geetech use their own threads. I tried ordering various MK10 (M7 size) nozzles for my A10M and they all have a different thread rake on them, and/or different internal diameter. Geeetech were very clever at only selling you THEIR nozzles. Too clever, as I will not be buying Geeetech anything in the future as this is a dirty money making trick.
