MeCreator 2 Z-Axis stuck
Posted: Fri Jun 21, 2019 4:27 am
by FactorTwo
Hello i have a problem with my printer. I have printed Something that was propably to large for the z Axis to comprehend, and now the buildplate is stuck at the buttom of the printer. IT doesnt even move a little bit i am affraid that i would break something if i try to forcefully push it up. Please Help me.
Re: MeCreator 2 Z-Axis stuck
Posted: Fri Jun 21, 2019 9:30 am
Hi,Do you mean that the hotbed can't move?
Posted: Fri Jun 21, 2019 7:26 pm
by FactorTwo
yes
Posted: Fri Jun 21, 2019 7:27 pm
by FactorTwo
William wrote: Fri Jun 21, 2019 9:30 am
yes
Posted: Sat Jun 22, 2019 9:05 am
Hi, You can 1. Check if the shaft is bent;
2. Check if the bearing is issued.
Posted: Tue Jul 02, 2019 8:02 am
by redirect303
My printer is new and it has the same issue. If the bed goes too low, it will lock and motor will start making strange noises.
I assume is a design flaw (or firmware)... Be careful also when manually moving the bed! The printer won't remember last Z position if turned off and then try moving the bed manually again (from the knob). Always do a homing when u power on printer, to make sure the coordinates are correct.
Now, to solving your problem: pull the bed support (the black one, not the aluminum bed), close to the rods and pull a bit upwards. Ideally use Repetier to manually do a Z move upwards (towards zero) at the same time when you do the pull. It will unlock if the problem is similar to mine.
!! is important to pull near the Z-rods, so you don't bend the bed.
- also, after such operation is good to check again your bed alignment
Posted: Mon Jul 08, 2019 9:07 am
Thanks for your feedback.
