Z axis stopped if I cancel printing
pepgra
Post by pepgra »
I use Bltouch and marlin 1.1.8 I find a problem when I want to cancel a print the Z axis is at the same point of cancellation, I see that other printers for example go up the Z axis, I guess it is a bug in Marlin 1.1.8.
My finalization script is correct, when the printing ends the Z axis separates from the part without problem and obeys, but when I cancel this does not happen.
I tried in S3d and Cura, same result
Re: Z axis stopped if I cancel printing
Hi, You can try to open z hop in the slicing software so that it does not scratch the print.
pepgra
Post by pepgra »
The problem is not that, the problem is that when you cancel printing the Z does not move, in other printers the output script is finished, but in Geeetech version 1.1.8 it does not
