Re: A10m heat break Jammed
Posted: Tue Sep 10, 2019 6:44 pm
				Hi, If you are referring to consumables stuck,
You can try to heat the hot end to 200° and then use the tool to push the consumables out.
If the nozzle is clogged, the specific operation can refer to this:https://www.youtube.com/watch?v=uKxPIGal74E
If the hot end itself breaks, it is recommended to replace it.
I hope this can help you.
