Hey all,
I have an A10 and I am looking to upgrade it to the A10M (dual filament)
I have a quick question that will sway my decision.
I really want to use the 2nd filament as PVA to use as detachable/soluble supports.
Has anyone done this or tried?
The main reason is for printing mini's that can be cleaned easily.
Thanks in advance.
							Thinking of upgrading to an A10M!!
Re: Thinking of upgrading to an A10M!!
 Hi, you may need to add an extruder motor, feeder, extruder motor line,Teflon tube
  Hi, you may need to add an extruder motor, feeder, extruder motor line,Teflon tubeThere are also hot end changes,
Then you need to make changes to the firmware.
For PVA materials you can refer to this: https://www.simplify3d.com/support/materials-guide/pva/
I hope this can help you.
