The connector on the NEMA 17 steppers appears to be a JST XH 2.54mm 6 pin male connector.  However, it is not - the pins are a lot closer together.
What type of connector is used on the NEMA 17 steppers ?
						Name of connector on NEMA stepper motor
Re: Name of connector on NEMA stepper motor
 Hi,I find this:https://reprap.org/forum/read.php?13,443769
  Hi,I find this:https://reprap.org/forum/read.php?13,443769-Keep your mind and try to test it.
