Hi All,
Just recieved my A10T and found out that the Y Axis moves and stops every few centimeters, as shown in the video bellow:
https://youtu.be/8tcULcPbpXc
I think that it is due to the cencentric bolts but am not sure - just wondered what is your take on it?
						A10T Y AXIS MOVE AND STOP EVERY FEW CENTIMETERS
Re: A10T Y AXIS MOVE AND STOP EVERY FEW CENTIMETERS
Hi, You can try to adjust your lock nut,
Then check if your y-axis guide is inwardly recessed causing this to happen.
It is normal issue of V-slot wheels. I have it too and printing...
If printer moves are smooth, then do nothing.
Apply drop of some good oil (motor oil, gun oil like Ballistol is best) to all bearings. And lithium vaseline to the Z-rod and extruder gear.
Later you could change wheels for new one.
A10 Slic3r profile: here
