				Crash when connecting x_m cable into the socket of the extrusion
				Posted: Wed Dec 25, 2019 7:41 am
				by Cleber
				when plugging then x_m cable into the extruder socket I smelled burnt smoke and the printer stopped working. What should i do? Which piece should I exchange? Help me
Print model: A10T
				Re: Crash when connecting x_m cable into the socket of the extrusion
				Posted: Wed Dec 25, 2019 9:26 am
  Hi, You can check if you can turn on the printer normally,
If it can be opened, what is the situation on the motherboard,
Check if there are signs of burnout.
Use a multimeter to measure the continuity of the wires you connect.
I hope this can help you.
