Page 1 of 2
Question about A20M fan placement
Posted: Thu Jan 02, 2020 8:47 pm
by rikku
I'm new to 3D printing. Recently, I had a problem with the hotend so I replaced it. But I don't take care about the 2 fans placements. Since, my printer often pause printing without error message. I just have to select "Resume" to continue but it's a little bit annoying for long prints.
I suspect I mount the 2 fans in a wrong way. Actually, the 2 fans take the air from outside to the hotend.
Could you confirm the direction of the air flow ? (I wonder if left fan take air to the hotend and the right to outside, but not sure).
Sorry for my stupidity -_-!
Re: Question about A20M fan placement
Posted: Fri Jan 03, 2020 9:32 am
Hi, The fans inside the hot end housing are on both sides of the hot end.
Is for cooling fans,
One left and right.
Posted: Sat Jan 04, 2020 6:31 am
by rikku
Thanks for answer.
My question is more about the direction of the air flow of each fans. Is it from inside the hotend to the outside or vice versa ?
I tried to draw my question, see files below
What is correct ?
Posted: Sat Jan 04, 2020 9:53 am
Hi,it is 2.
Posted: Sat Jan 04, 2020 10:30 pm
by Jarda3d
No. 2???
On my A10M it was configuration No.1 from factory (2018/10 model). Warm flow is going to printed model.
So what is right in reallity?
Posted: Sun Jan 05, 2020 2:19 am
by rikku
Jarda3d wrote: Sat Jan 04, 2020 10:30 pm
No. 2???
I don't think the fans on the sides go to the model. It's the 3rd fan's role, the one with a duck to cold the print. Maybe I'm wrong ?
Posted: Sun Jan 05, 2020 5:35 am
by Jarda3d
Maybe.
I am waiting to official Geee answer about fan direction...
Posted: Sun Jan 05, 2020 10:13 pm
by chc
I want to change the fans, in order to get something quieter.
Does someone has good links to quieter fans?
Power supply's Fan :
60*60*15 mm / 12 V / 0,2 A
MotherBoard's Fan
50*50*20 mm / 24V
Best regards,
Christophe
Posted: Mon Jan 06, 2020 7:42 am
by Jarda3d
Look at my signature
Posted: Mon Jan 06, 2020 10:44 am
by Admin
oh, Jarda3d is right.
