Y printing offset problem
Posted: Tue Mar 17, 2020 12:33 am
by MagicALL
Good morning all
I have a problem on the Y axis.
printing is shifting!
no hard point, at the belts, pulleys ...
I think it's at the level of electronics.
I adjusted the four motors which were often hot at 1,2V, beetwen screw and ground
Is it correct??? for all motors?
thanks
Re: Y printing offset problem
Posted: Tue Mar 17, 2020 10:20 am
Hi,If the motor overheats,
Can be adjusted to about 1V,
Print in a well-ventilated area.
Posted: Tue Mar 17, 2020 9:26 pm
by MagicALL
I set at 1 Volts motors, but only the Y not work...
Is it possible was down?
date on motor 27/02/2017
Is there to sold on store? because he have different fixing.
regards
Posted: Wed Mar 18, 2020 10:40 am
Hi, you can try swapping the driver board to see the situation.
Posted: Wed Mar 18, 2020 6:39 pm
by MagicALL
Hi William, thanks for support...
I swap the stepper on mother board, but same problem.
I try to swap motor, (Pulley, screw), but power and rear fixing are not same.
At start the rotation was reverse, big worries.
Then I try to find a new motor , (this printer was a reconditioned) It work fine, but the printer suddenly has shifted, only axe Y.
Regards
Re: Y printing offset problem -update 25 March
Posted: Sun Mar 22, 2020 10:23 pm
by MagicALL
HI
I m looking for Vref 1.2V not work
I give you more information to help me:
Drver A4988 with R200
Motor 42SHD0217-24F at current ratted 1.5 A
the vref is:
vref = 8 x 1.5 x 0.200
or
Vref= 8 x 1.5 x0.068
regards
