Horizontal "pits" are repeated on the 3D model (maybe not a wobbling)
Posted: Tue Apr 14, 2020 1:32 am
by wazls
On any model there are such "pits", how to solve this problem?
Note:
- the 3D model's fan does not work (broken)
- PLA plastic (temperature: nozzle-210, bed-55)
Thanks!
Re: Horizontal "pits" are repeated on the 3D model (maybe not a wobbling)
Posted: Tue Apr 14, 2020 9:27 am
Hi, You can check whether the lower z-axis threaded rod is bent or caused by missing teeth,
Check whether the mechanism is loose and fasten it.
Posted: Tue Apr 14, 2020 7:15 pm
by wazls
I printed out and installed this model while there are no deep pits. Apparently the Z axis isn't exactly perpendicular
Posted: Wed Apr 15, 2020 10:50 am
you can check whether the Z-axis threaded rod shakes.
If the fan is damaged, you can lower the temperature appropriately.
Posted: Wed Apr 15, 2020 3:30 pm
by wazls
Just a little bit, minimal backlash to the left and right. I think this is not critical. So far the problem seems to be fixed, I hope for a long time.
