Thermal runaway longshot
Posted: Fri Apr 24, 2020 1:59 am
by Cg83
Having some more thermal runaway issues with my heated bed. Is there any way to adjust these settings using gcode commands by chance? I dont really want to recompile the firmware. Running Verts 2+ Build 493. Also Ive got a a10m and changed to a non geared extruder. What specific lines do i need to change to get the extruders to run the right way now?
I know the thermal runaway is probably not in a gcode command but wanted to ask. If I am going to recompile Id like to know where to fix the extruder direction is, as I dont remember now.
Re: Thermal runaway longshot
Posted: Fri Apr 24, 2020 10:26 am
Hi,if you need to change the direction of the motor,
you can refer to this:viewtopic.php?f=17&t=17037
Posted: Fri Apr 24, 2020 1:47 pm
by Cg83
William wrote: Fri Apr 24, 2020 10:26 am Hi,if you need to change the direction of the motor,
thanks i somehow missed it like an idiot
