Good morning,
I recently was doing maintenance on my A10M and accidentally crushed my hot end thermistor when reassembling it. The part number supplied from Geeetech is PT3-25E2-S2 and I have already put one on order. I am attempting to print some face shields for my local hospital and am trying to find an equivalent thermistor to use due to shipping delays. Does anyone know what Hot End Thermistor will work that may be more readable available?
A10M Hot End Thermistor
Sodium100mg
Re: A10M Hot End Thermistor
The A10M specification shows a Heater cartridge: 24V, 40W; diameter & length: 6 *30mm
Amazon has a 5 pack for $11 of 24v, 40W with a 6mm diameter. The length won't matter as long as the wattage and diameter is correct and I'd bet the one you have also measures 20mm. With amazon prime, I can have them by monday
https://www.amazon.com/Ewigkeit-Heater- ... B07FS4Q5SB
The thermistor is the temperature sensor. Here is a link to the one I purchase, though I was instructed to include in the order description:
"Need A10M thermistor: PT3-25E2-S2"
https://www.geeetech.com/10pcs-100kohm- ... p-632.html
Sodium100mg
DOH! Sorry, my brain isn't working right these days.
This is one for the ender, which the geeetech is based on
https://www.amazon.com/Tulead-NTC3950-T ... B07WRWM9TM
