Geetech a10m x-axis belt motor slide?
AustinGreyson
I have my belt which makes a left right on the notched wheel of the x axis, I try everything to center the belt, tighten, loosen, check the right fastener (right side). I even add guides but it is still right to left. since what made it (new 1 month) I have my first layer that exceeds (same piece from the beginning, same stl.)
Re: Geetech a10m x-axis belt motor slide?
Hi,can you provide pictures or videos?
