Use of GT2560 in place of the V4 for A10 pro
imag2020
Post by imag2020 »
The GT2560 V4 of my new A10 pro is not working (some capacitor was out of voltage and now it's not powring on)
I get a classical GT2560 but the connections of the LCD+SD is not the same.
In the two cards there is 20 pins but in the V4 all are in the same 'package' and in the card I buy there is two connections of 10 each, one for LCD and one for SD.
So I need the schema to connect LCD+SD of my A10 pro to the two connections of the 'old' GT2560
Hope my question is easy to understand, here is a photo for more details
Thank you in advance.
Re: Use of GT2560 in place of the V4 for A10 pro
Hi,your question is whether this solution is feasible?
imag2020
Post by imag2020 »
Hi William,
My question is how to do that ? it must be possible, All I need is only to know each pin on both sides: on the ( GT2650 revision A+ card) and on the LCD/SD of my A10 pro printer.
Thank you.
Sorry. This is not feasible, the pins are different, and the firmware cannot be changed.
imag2020
Post by imag2020 »
Thank you for your response,
I already update firware of my G2560 revison A card,
Can you please help me to find pins description of the LCD of my A10 pro ? (there is 20 pins) any shema or notice ? I'll handel that
Correspond to this picture:
imag2020
Post by imag2020 »
Thank you a lot William,
There's 20 pins in the LCD of my new 10pro, ther's only 10 on your schema. :roll:
Sorry for the mistake, this is
imag2020
Post by imag2020 »
Thank you very match William,
So this is the pins of my LCD here (see pics)
I'll try and let you informed
Thank you again
Corresponds to this direction
