problems printing detail and overhangs??
Posted: Mon Jul 20, 2020 2:55 pm
by SheldonCooper1
I got my A10 PRO from amazon and ever since it arrived I have had nothing but problems.
the bed would not level I had to get a glass bed for it. after getting a glass bed I was able to level and get good first layers.
I have calibrated the extruder and seams to be accurate. (checked with digital calipers )
no matter my settings Speed Test essay writer I am not able to print any overhangs without it turning into spaghetti.
when printing any top layer detail there is a lot of stringing and the extruder carves into the print
I am using cura 4.3
all my prints are in PLA I have tried 6 different PLA's with all the same results
I have tried increasing and decreasing heats and print speeds with the same results
Re: problems printing detail and overhangs??
Posted: Wed Jul 22, 2020 8:50 am
by bruse2020
Was having similar problem so i reduced the cooling fan speed and increased the temp to 215 and it worked for me. fan seed was reduced to 60%
Posted: Sat Mar 27, 2021 2:31 am
by robinjamess
SheldonCooper1 wrote: Mon Jul 20, 2020 2:55 pm I got my A10 PRO from amazon and ever since it arrived I have had nothing but problems.
no matter my settings I am not able to print any overhangs without it turning into spaghetti.
I am using cura 4.3
TcsWebmail DadeSchools Upsers
Hi!
So I’m trying to move over to SainSmart TPU from Eryone and am tuning my settings, but no matter what I try I keep getting these issues on my overhangs.
All units of measurement are metric in the following settings.
Here are my settings:
Temp: tried from 195-206
Layer height: 0.12
Print speed: tried 35mm/s and 40mm/s
Retraction distance: tried from 7mm to 18
Retraction speed: tried from about 17mm/s to 30mm/s
Jerk setting: tried 4 and 8
Acceleration: tried 250mm/s2 and 500mm/s2
Bed temp: 60
Number of walls: 3
Infill percentage: tried 20-25, both Gyroid and cross
Fan speed: 100% on affected region
The overhangs at the top of the cabin are fine
Printer on a Bowden setup with upgraded metal extruder and SainSmart black filament
Sliced in Cura 4.7.1
Any help is appreciated - thanks!
