So i bought the geeetech a10 printer a while ago, this is my second printer.
I was flashing the firmware so i could use the bltouch sensor and now my printer wont work, the lcd is just two rows of black squares in cura it detects the printer but i can only heat up the build plate and nothing else works ive tried to find the default firmware to reflash back to the way it was but arduino keeps giving errors on most files i find.
i followed instruction perfectly i used the right config.h file and set the motherboard in the file but it still will not work please help me.
							Geeetech A10 Bricked! need help!
				josnailai94
Re: Geeetech A10 Bricked! need help!
if you have an arduino uno you can reflash the ATMEGA2560 the A10 runs on directly, i can help you with it as my printers usb to serial chip has died. you do need to solder a wire to the mainboard, but the rest you can use m to m dupont adapters from the displays 20 pin connector
just so you know, this will most likely fix your issue as this method wipes eeprom and reflashes the bootloader along with the usual marlin software
