Videos of MK8 Extruder assembly
zhangxueyou
Post by zhangxueyou »
In this video, you will see how to tear the mk8 extruder down, and how to replace new extruder kits.
https://www.youtube.com/watch?v=aPvVUZQnOMM
How to replace extruder thermistor:
https://www.youtube.com/watch?v=FR0n2FHrjmc
How to replace nozzle:
https://www.youtube.com/watch?v=t2tUxrZDi8o
How to level dual extruder:
https://www.youtube.com/watch?v=XGpcueI ... e=youtu.be
mava70
Re: Videos of MK8 Extruder assembly
Post by mava70 »
hello the heater and the thermistor move inside the hole out and in, can be fixed someway?
Mark
Post by Mark »
there's a setscrew for the heating cartridge, did you see that? and you can use a cable tie to tie them up.
mava70
Post by mava70 »
Hello there is a small hex screw next to the hole in the back but I tryed to turn clockwise the screw go inside the hole a lot but don't fix. Should I turn a lot more?
Mark
Post by Mark »
I remember the setscrew is side of the heating block not in the back, maybe you need to remove the sponge thing to check it, and you can screw it a little tight.
calabrovarijo
Post by calabrovarijo »
zhangxueyou wrote: Fri May 29, 2015 10:35 am In this video, you will see how to tear the mk8 extruder down, Audacity Find My iPhone Origin and how to replace new extruder kits.
randyhavens
Post by randyhavens »
You can try removing the sponge thing to check it, and screw it a little tight.
gmail sign up
