Screen, Drivers
elkt3k
Screen, Drivers
Post by elkt3k »
my screen is jumbled up with a bunch of lines. and i cant get the drivers to install correctly.
checking on my device manager screen i tried to update them, but windows is saying i have the best drivers up to date.
i downloaded them manually from the forum here and tried to install them.
i clicked browse from a category for update. i chose subfolder of where the dlls are located but it keeps saying i have the best up date drivers.
why is my screen all jumbled?
when i first set up the I3 M201 the psu switch was set to 220 instead of 110 and wouldnt start. then i noticed the switch and changed it.
it powered on and then the right extruder fan burned up and shorted it. I had it plugged in pwm fan, instead of fan. is this the right order? or was the way i had it correct?
Re: Screen, Drivers
Post by _kaktus_ »
Hello.
It's very sad what happened to you. :o
In the second topic, answered about the display.
Your problems will be solved one by one, not all at once.
At the moment, we have two subjects to discuss.
  1. The display does not work properly.
  2. The printer does not communicate with the computer via USB.
Yes? :?:
elkt3k
Re: Screen, Drivers
Post by elkt3k »
That is correct yes
Re: Screen, Drivers
Post by _kaktus_ »
Hi.
Keep us informed about your actions and effects. ;)
