I am using a 3D-Touch bed leveling sensor configured as per the instructions I was provided two and a half years ago. The printer works fine with the old 1.0.x code, but i want to use some of the newer features of the 1.1.x code.
I found the PINs files are "sort of hard coded" to the new PLUS version of the board.
If you have the BOARD_NAME defined as the GT2560A+ the pins-gt2560a+ file is included at compile time. that file looks like this:
Code: Select all
* Geeetech GT2560 Revision A+ board pin assignments
#define BOARD_NAME "GT2560 Rev.A+"
#include "pins_GT2560_REV_A.h"
#if ENABLED(BLTOUCH)
#define SERVO0_PIN 11
#else
#define SERVO0_PIN 32
#endifIf you have the BOARD_NAME defined as the GT2560A there is no reference for a BL-Touch in the pins_GT2560A file. It looks like this:
Code: Select all
* Geeetech GT2560 Revision A board pin assignments, based on the work of
* George Robles (https://georges3dprinters.com) and
* Richard Smith <galorin@gmail.com>
#if !defined(__AVR_ATmega1280__) && !defined(__AVR_ATmega2560__)
#error "Oops! Make sure you have 'Arduino Mega' selected from the 'Tools -> Boards' menu."
#endif
//#ifndef BOARD_NAME
#define BOARD_NAME "GT2560 Rev.A"
//#endif
#define DEFAULT_MACHINE_NAME "Prusa i3 Pro B"
// Limit Switches
#define X_MIN_PIN 22
#define X_MAX_PIN 24
#define Y_MIN_PIN 26
#define Y_MAX_PIN 28
#define Z_MIN_PIN 30
#define Z_MAX_PIN 32
// Steppers
#define X_STEP_PIN 25
#define X_DIR_PIN 23
#define X_ENABLE_PIN 27
#define Y_STEP_PIN 31
#define Y_DIR_PIN 33
#define Y_ENABLE_PIN 29
#define Z_STEP_PIN 37
#define Z_DIR_PIN 39
#define Z_ENABLE_PIN 35
#define E0_STEP_PIN 43
#define E0_DIR_PIN 45
#define E0_ENABLE_PIN 41
#define E1_STEP_PIN 49
#define E1_DIR_PIN 47
#define E1_ENABLE_PIN 48
// Temperature Sensors
#define TEMP_0_PIN 8 // Analog Input
#define TEMP_1_PIN 9 // Analog Input
#define TEMP_BED_PIN 10 // Analog Input
// Heaters / Fans
#define HEATER_0_PIN 2
#define HEATER_1_PIN 3
#define HEATER_BED_PIN 4
#define FAN_PIN 7
// Misc. Functions
#define SDPOWER -1
#define SDSS 53
#define LED_PIN 13
#define PS_ON_PIN 12
#define SUICIDE_PIN 54 // Must be enabled at startup to keep power flowing
#define KILL_PIN -1
#if ENABLED(ULTRA_LCD)
#define BEEPER_PIN 18
#if ENABLED(NEWPANEL)
#if ENABLED(MKS_MINI_12864)
#define DOGLCD_A0 5
#define DOGLCD_CS 21
#define BTN_EN1 40
#define BTN_EN2 42
#else
#define LCD_PINS_RS 20
#define LCD_PINS_ENABLE 17
#define LCD_PINS_D4 16
#define LCD_PINS_D5 21
#define LCD_PINS_D6 5
#define LCD_PINS_D7 6
#define BTN_EN1 42
#define BTN_EN2 40
#endif
#define BTN_ENC 19
#define SD_DETECT_PIN 38
#else // !NEWPANEL
#define SHIFT_CLK 38
#define SHIFT_LD 42
#define SHIFT_OUT 40
#define SHIFT_EN 17
#define LCD_PINS_RS 16
#define LCD_PINS_ENABLE 5
#define LCD_PINS_D4 6
#define LCD_PINS_D6 20
#define LCD_PINS_D7 19
#define SD_DETECT_PIN -1
#endif // !NEWPANEL
#endif // ULTRA_LCDI have a work around that corrects the lack of BL-Touch pin assignments for a GT2560A. I would not try to use this modified code for a GT2560A+ board however.
My work around:
Code: Select all
// Limit Switches
//#define Z_MAX_PIN 32
#define Z_MAX_PIN -1
#else
#define SERVO0_PIN 13
#endif
// Steppers
/With these changes the auto homing and bed leveling from the control panel appear to work fine.
