Bed says 107c when it is cold and it has been cut off
My a10 heated bed says 107c and only will get hot if I turn it up to 108 c have no clue just got it. Had 5 days now.
Re: Bed says 107c when it is cold and it has been cut off
Hi,are you saying that the hotbed is heated to 108°? The temperature is a bit amazing.
No with the heat off it says it is 108 but the bed is cold I can turn bed to 110 and it will heat to 57c.why is it stuck on 108 when it's not on but bed is cold.
William wrote: Wed Jul 24, 2019 9:48 am Hi,are you saying that the hotbed is heated to 108°? The temperature is a bit amazing.
Hello.
This may indicate a problem in the measuring circuit of the thermistor.
I suggest you disconnect the thermistor and check the behavior of the system. If you have a multimeter you can measure whether there is a short circuit somewhere and whether the thermistor is working properly.
