Easyprint software for WINDOWS
Re: Easyprint software for WINDOWS
The user manual is out of date
There is a bug in connection "Control"
Nozzle temp can turn on via toggle switch, but can not turn off by toggle switch.
you can turn off by clicking on temp slider or value box.
all other controls work correctly Run, Fan, Bed. but nozzle temp is wrong.
Re: Easyprint software for WINDOWS problem
Ciao a tutti sono nuovo del forum, ho da poco acquistato una i3 prusa w e dopo aver provato a scaricare easyprint3d mi esce la finesta che vi allego qui sotto!
aspetto con ansia un aiuto, sia per questo problema e sia per il problema no sd card!
Grazie tanto a tutti...
System.IO.FileNotFoundException: Il file 'C:\Users\ciara\AppData\Roaming\easyprint\work\composition.gcode' non è stato trovato.
Nome file: 'C:\Users\ciara\AppData\Roaming\easyprint\work\composition.gcode'
in System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
in System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
in System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
in RepetierHost.view.StoreCode.CopyAndReplace(String path, String path_des)
in RepetierHost.view.StoreCode.buttonSave_Click(Object sender, EventArgs e)
in System.Windows.Forms.Control.OnClick(EventArgs e)
in System.Windows.Forms.Button.OnClick(EventArgs e)
in System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
in System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
in System.Windows.Forms.Control.WndProc(Message& m)
in System.Windows.Forms.ButtonBase.WndProc(Message& m)
in System.Windows.Forms.Button.WndProc(Message& m)
in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Assembly caricati **************
mscorlib
Versione assembly: 4.0.0.0
Versione Win32: 4.7.3416.0 built by: NET472REL1LAST_B
Base di codice: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
EasyPrint3D
Versione assembly: 1.0.0.0
Versione Win32: 1.0.0.0
Base di codice: file:///C:/Program%20Files%20(x86)/Geeetech/EasyPrint%203D/EasyPrint3D.exe
Versione Win32: 4.7.3324.0 built by: NET472REL1LAST_C
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Versione Win32: 4.7.3056.0 built by: NET472REL1
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
OpenTK
Versione assembly: 3.0.0.0
Versione Win32: 3.0.0
Base di codice: file:///C:/Program%20Files%20(x86)/Geeetech/EasyPrint%203D/OpenTK.DLL
System.Configuration
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
Versione Win32: 4.7.3362.0 built by: NET472REL1LAST_C
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Data
Versione Win32: 4.7.3260.0 built by: NET472REL1LAST_C
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Numerics
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Windows.Forms.resources
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_it_b77a5c561934e089/System.Windows.Forms.resources.dll
Accessibility
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
OpenTK.GLControl
Base di codice: file:///C:/Program%20Files%20(x86)/Geeetech/EasyPrint%203D/OpenTK.GLControl.DLL
mscorlib.resources
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_it_b77a5c561934e089/mscorlib.resources.dll
************** Debug JIT **************
Per abilitare il debug JIT, è necessario impostare il valore
jitDebugging nella sezione system.windows.forms del file di configurazione
dell'applicazione o del computer (machine.config).
L'applicazione inoltre deve essere compilata con il debug
abilitato.
Ad esempio:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Quando il debug JIT è abilitato, tutte le eccezioni non gestite
vengono inviate al debugger JIT registrato nel computer,
anziché essere gestite da questa finestra di dialogo.
mscorlib
EasyPrint3D
System
System.Drawing
OpenTK
System.Core
System.Xml
System.Data
System.Numerics
Accessibility
OpenTK.GLControl
mscorlib.resources
abilitato.
Ad esempio:
<configuration>
</configuration>
Maybe this error happens because there is no infill field... i had this problem in an older version if I set Infill to 0% or 100% I don't know which parameter in the config file you should change but I hope a programmer will fix this error.KanKar wrote: Sun Sep 23, 2018 1:45 am Hi all,
i have just installed Easyprint 1.2.6 to on a laptop with win 10 Enterprise
When I load an stl model and press the button Slicer the program complains with this message:
Any idea how to fix this error?
Best regards.
Hi, Config-language in menu options
There are two options in Chinese and English.
