[SOLVED] problem 3d touch G29
Goodmorning, yesterday i have installed 3d touch . but i have some problem. When i write the g28 code work well and go to home,the 3d touch reaches the base and stops . but when i write g29 ,goes into first corner (led of 3d is off) with the pin all lowered, but when touch the base it never come up and i force shutdown for not create damage.
thanks
thanks
Re: problem 3D Touch G29
Hi, Hi, you need not put another G28 after the G29 as it will just remove the G29 results.
and the G29 command should be added every time.
for specific operations, you can refer to this:http://www.geeetech.com/wiki/index.php/ ... ing_Sensor
I hope this can help you.
Re: problem 3d touch g29
yes but when put g29 only code for bed leveling, it s goes down to much. how can modify the height
but when put in home is perfect
thanks
thanks
Hi, Whether you have calibrated 3d touch, you can refer to this: ; pushes the pin down
; pulls the pin-up
; Self-test – keeps going until you do pin up/down or release alarm
; Release alarm.
Code: Select all
M280 P0 S10
Code: Select all
M280 P0 S90
Code: Select all
M280 P0 S120
Code: Select all
M280 P0 S160
Re: problem 3d touch G29
thank for response. i solved the problem. but can ask you for a good setting for a 0.6 nozzle with pla? thanks
i lowered all speed at 25 30 mm/s but , in slic3r default extrusion widht is correct insert 0.6 or little higher . perimeter , top and bottom i have insert 1.2 .
thanks
Paolo
thanks
Paolo
Hi everybody,
hope someone can help me.
I think I have read all the issues you got on the topic "3D Touch", but unfortunatly I didn't find a solution for me.
First of all: I have a I3 Pro B with 2650 A+ (if I corretly understand, it could mean something since I have the 3D Touch pins close the Extr. Term.).
I followed the steps (many times) on the manual but it is for 2560.
According to the firmware available in the forum I got the firmware already set up for my printer. Easy (I checked if the instructions are in place...there are)
Finally I can drive the command M280...all of them
I have set up the printer (as indicated in the instruction)..BUT (of course there is a BUT otherwise I was printing at this moment..
I can't go further with the calibration since when I send:
M851 --> echo:Z Offset : -0.50
M851 Z0 --> echo:Z Offsetz_min: -15zmax: -5
G28 --> the printer starts to set home: ok for X and Y axes but for Z is a mess! The nose of the 3D touch seems to work but it doesn't stop anything so the extruder touch the bed,,,pushing and pushing the bed so I have to send the stop command...and the 3d touch is fashing
Where is the problem?
thanks,
m
thanks,
m
SOLVED
in my case the problem was related to wrong connection with z stop: I have readed (in this forum) there wasn't a polarity.
Just swap the cable,,,and is ok,
About calibration...it should be easier, Geeetech thanks to provide detailed information for EACH of your product, not easy or serious have to spend 20 hours for a plugin (from the same brand).
Ciao,
m
Ciao,
m
