Cura 4.2.0 and the A30 Settings [Important]
CallXYZ
Post by CallXYZ »
Today a new version of Cura was released.
The A30 Printer was added to the printer list.
Unfortunately if you add it from the list, your printer wont work.
The Config file in the new version is wrong and also the Start Code is doing only strange stuff.
I have corrected the config file. Please change the file in "Program Files\Ultimaker Cura 4.2\resources\definitions" and use the attached version.
The Heatbed STL can be found here: viewtopic.php?t=61552
Also can somebody please double check my file, just in case.
For example the code flavor was changed to repertier in the wrong file but should be marlin.
There are also a few more entries inside than in the old file.
Geeetech_A30.def.zip
(965 Bytes) Downloaded 905 times
Re: Cura 4.2.0 and the A30 Settings [Important]
:D thanks for your share.
TheG
Post by TheG »
Can a Mod/Admin please make this sticky? :)
rj16066
Post by rj16066 »
Question.... All I see is a A30M in the list. Will this profile work on a standard A30
New to 3D printing..
Rj
rj16066 wrote: Mon Aug 05, 2019 4:31 am Question.... All I see is a A30M in the list. Will this profile work on a standard A30
Rj
Hi, You can download the firmware of the A30 from the official website.https://www.geeetech.com/download.html?download_id=38
Then refer to this to update :http://www.geeetech.com/forum/viewtopic ... 20&t=68694
I hope this can help you. :D
SirSunshine
Post by SirSunshine »
Thank you for posting this. I've been fighting my Z manual leveling since the last firmware. Hoping this version fixes it. Had no idea a new version was out.
Marcellus
Post by Marcellus »
Rj
Hello
Dont look for Geetech! Look for Shenzhen Getech Technology, there you will find the A30...
Greets
RebelDGX
Post by RebelDGX »
Hi, i get a crash in cura 4.2.1 after selecting the A30 printer from the list, i can select the A30M and no problem, the crash happens only when i select the A30, tried reinstalling cura and downloading again the resources ZIP file but keep getting the crash.
CallXYZ
Post by CallXYZ »
I have not yet upgraded to 4.2.1 because the setup works good right now and I have a few prints waiting.
After that I will install the new version.
