Hi, You can 1. Check if your Teflon tube is fully connected;
2. Heat the nozzle to 200° and manually feed the consumables to see if it can be discharged normally.
Determine if the nozzle is blocked;
3. Check if the Teflon tube has any waste.
I hope this can help you.
A30 problem
Re: A30 problem
