A30 Bed level operation in Cura via USB/SD
CallXYZ
Post by CallXYZ »
When printing a file directly from the SD card with the A30 with Sensor, the printer is performing a checkup/leveling of the bed before printing.
It checkes 10 points on the bed.
When printing with Cura over the USB cable, the printer is performing only a short test and is touching only the middle of the bed.
Judging from the print quality, the detailed checkup/leveling with 10 measuring points is needed to ensure good quality
My guess is that Cura needs instructions for the detailed checkup/leveling in the start gcode.
Can we get the correct instructions for the start gcode?
Re: A30 Bed level operation in Cura via USB/SD
Hi, You can level the points of the hot bed before printing starts.
