Mecreator 2
Radar1002
Mecreator 2
Post by Radar1002 »
Hello
I have a problem with my Mecreator 2. After a firmware update there are only bars in the display.
the Com Port is still recognized but I don't manage to install the firmware again. Who can help ? Did I destroy the board ? sorry for the bad English, I come from Germany and use Deepl as translator. Thanks
Re: Help Mecreator 2
HI, You can try to reconnect the screen cable.and your firmware update may have errors.
You can download the compiled HEX format firmware on the official website.
you can refer to this :https://www.geeetech.com/download.html?download_id=37
Then use the CURA slicing software to connect to the printer.
Use Settings-printer-manger printer
Update the firmware.
I hope this can help you.
Radar1002
Post by Radar1002 »
Thanks for the quick answer. I have tried the suggested steps but unfortunately without success. Cura says that no printer is connected and the display wiring is OK.
Hi, If the driver cannot be installed automatically,
You can refer to this:https://www.geeetech.com/download.html?download_id=40
and install the appropriate driver according to your needs.
:https://www.geeetech.com/forum/viewtopi ... RlcFtWdCG4
Install the driver manually.
Radar1002
Post by Radar1002 »
Ok , Also reinstalled the drivers and tried the firmware update again in several ways . Unfortunately this was also without success. think the board is defective. Cura says no printer connected, Arduino gets no answer from the motherboard.
Hi, You can try to replace the USB cable and try it out;
If it is still not possible to update,
You can contact your sales to replace the motherboard.
Radar1002
Post by Radar1002 »
i have now looked for a new board . but find only boards of the Rev 3 . can i use this for the printer ?
Hi, The motherboard of MeCreator is GT2560_Rev_B.
You can contact your sales for consultation.
Re: Mecreator 2
Post by _kaktus_ »
Hello Radar1002
I think the bootloader was probably damaged. This is a special "part" of the firmware. It is responsible for the possibility of updating the firmware. ;)
I expect that when you reload it, the update will be possible.
MagicALL
Re: Mecreator 2
Post by MagicALL »
Hi William
I use CURA and I update with the HEX firmware for my MC2.
Because i See it s last date firmware.
What is the difference or the good on forum firwamre:
MeCreator2固件.zip
(293.54 KiB) Downloaded 5250 times
Update:new version of mecreator2
(fixed the print area not correct)
MeCreator2-1.0.4.zip
(305.39 KiB) Downloaded 1211 times
Why put 2 for 1 machine?
The update works fine. But it seems that the print size of the bed is offset.
I put
x:160 - y:160 - z:160
xmin: 0 - ymin:0 - zmin: 0 - gantry 99999
Rectangular
Only Heated bed select
Gcode marlin
this gcode:
Code: Select all
G28 ;Home
G1 Z15.0 F6000 ;Move the platform down 15mm
;Prime the extruder
G92 E0
G1 F200 E3
G92 E0
and I run a printing:
But the X carriage tap into the left side chassis
The size of print is only 140.
There seems to be a decallage,between the X origin and the X of the table after HOME origin.
Thanks for your help boss
Regards
