Hard point on z axi
Re: Hard point on z axi
Look the screw.
- IMG_20190916_201012.jpg (273.92 KiB) Viewed 7333 times
OH, if the one shown now is the same as the one you provided, you need to fix it.
What should I fix, I do not understand well?
In the photo, the 2 new support (front and back) are installed, they are new. In fact I have the impression that the hole of the support falls before the hole of the wheel the support should I think to come more to the right. But that can not be solved if the geeetech A30?
My screw is more longer. No ?
Hi,Do you remember how you removed it?
You need to fix it with a screw.
No, I thought the bearing screws were all the same size.
I am not very clear about what you mean.
I'm at work, 1 hour from home
Tonight, I'll see to redo pictures for you to understand better.
