Problem with firmware
Rush68
Post by Rush68 »
whats Mean
Code: Select all
Arduino:1.8.10 (Windows 7), Tarjeta:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch\SdBaseFile.cpp:24:0:
SdBaseFile.h:38:8: error: using typedef-name 'fpos_t' after 'struct'
 struct fpos_t {
                 from sketch\SdBaseFile.cpp:21:
sketch\SdBaseFile.cpp: In member function 'void SdBaseFile::getpos(fpos_t*)':
SdBaseFile.cpp:298:8: error: request for member 'position' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
   pos->position = curPosition_;
SdBaseFile.cpp:299:8: error: request for member 'cluster' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
   pos->cluster = curCluster_;
                 from sketch\cardreader.h:8,
                 from sketch\Marlin_main.cpp:50:
 struct fpos_t {
sketch\SdBaseFile.cpp: In member function 'void SdBaseFile::setpos(fpos_t*)':
SdBaseFile.cpp:1485:23: error: request for member 'position' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
   curPosition_ = pos->position;
SdBaseFile.cpp:1486:22: error: request for member 'cluster' in '* pos', which is of non-class type 'fpos_t {aka long long int}'
   curCluster_ = pos->cluster;
                 from sketch\SdFile.cpp:23:
 struct fpos_t {
                 from sketch\SdFile.cpp:20:
Se encontraron varias bibliotecas para "LiquidCrystal.h"
Usado: C:\Program
exit status 1
Este informe podría contener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
Rush68
Re: Problem with firmaware
Post by Rush68 »
It's a mistake when verifying the firmware, my printer is a Delta Rostock mini G2s pro
Hi, about firmware you can refer to this:http://www.geeetech.com/forum/viewtopic ... 20&t=17046
