First of all, I bought a Geeetech 3D Touch for my I3 Pro B printer, and it works great!
But I think Geeetech should put a little more effort in to make it much more easy to install. As someone said: the wires are short, and need some rewiring (into the 2 pole connector).
If Geeetech could make this a "just pop it in and plug it in" (and configure) type component, this could be an easy upsell or profit maker -- my printer works so reliably now and leveling is perfect!
Also, please take care to update the instructions, too, to be more clear.
3D Touch is great!
Re: 3D Touch is great!
Hello.
Your opinion is very valuable.
You simply want the product to be user-friendly ...
Loadmaster
I wish I could say the same. I'm not having luck with the 3D Touch. The best repeatable numbers are far above the specs. .5mm. I'll most likely send the two I purchased back. One is a little better than the other, but not by much. My original BL Touch was very consistent at 0.03mm. So much for trying the 3D Touch.
Let's solve it together.
