design files for acrylic frame parts
csrf
Post by csrf »
Attn Geeetech,
can you please provide the design files for the acrylic frame parts? I would like to make my own replacement frame parts for the Y-axis frame on my geeetech I3 pro X.
At the minimum, can you please provide the dimensions & spacing for the holes for the threaded rods & smooth rods of the Y-axis on the I3 pro X? This way, I can design my own parts.
Thanks,
Admin
Re: design files for acrylic frame parts
Post by Admin »
Y-axis polished rod size: 420mm, φ8
Y-axis threaded rod size: 450mm M10
csrf
Post by csrf »
Admin,
thanks, but I meant the dimensions/distances between the holes. I need to replace the acrylic plates for the Y-frame. I want to rebuild the Y-frame with the traditional prusa I3 design, using threaded rods & 3D printed parts, instead of using a solid acrylic plate.
I need to know the height & distances between the threaded & smooth rods.
Please see picture:
Post by _kaktus_ »
Hello.
Many elements of printers are available on the forum. Unfortunately, this is done quite haotically.
As a reminder, I will repeat the ones that were made available earlier.
  • 2018-01-22 11:36 252˙584 PI3B1-C08-z-top.STL
    2018-01-22 11:37 139˙984 PI3B1-C09-PlatformH.STL
    2018-01-22 11:37 187˙284 PI3B1-C10-PlatformH.STL
    2018-01-22 11:37 163˙484 PI3B1-C11-PlatformH.STL
    2018-01-22 11:37 182˙984 PI3B1-C12-PlatformH.STL
    Pro X stl.zip
    STL file parts
    (184.73 KiB) Downloaded 856 times
  • 2018-08-13 11:46 117˙084 A6.STL
    2018-08-13 11:47 102˙984 A7.STL
    2018-08-09 08:24 182˙984 PI3B1-C12-PlatformH.STL
    2018-08-09 08:26 145˙284 PI3B1-C13-Ymotor.STL
    2018-08-09 08:27 95˙484 PI3B1-C14-fixer for yplatform.STL
    2018-08-09 08:28 147˙784 PI3B1-C17-XMotorTB.STL
    2018-08-09 08:28 323˙884 PI3B1-C29-Carriage.STL
    I3 X.zip
    STL file parts
    (223.69 KiB) Downloaded 851 times
Files can be used for private use, and should not be shared with other services. :!:
When you have finished your project, show off your work. :D
gibsontrevor111
Post by gibsontrevor111 »
Do you know basketball stars? This is a popular sports game today. It can help you to relax after a long day working or studying. Try playing it to have funny moments.
