Z axis motors moving in opposite direction to each other!!!
Anurakclark
Post by Anurakclark »
Hi guys,
Just in the process of setting up the printer, ive got to the stage the test the homing positions and have encountered a problem.
Ive tried searching, but having seen any posts on my issue.
When using Repetier, connecting to the printer and commencing the manual home, the x and y axis work fine. They hit the end stop and the test progresses to the next motor test. The last stage, the z axis motors turn in the opposite direction to each other. Left side is .reverse phone lookupnba reddit pcpartpicker
When adjusting the firmware (True/false) this just switches the issue, left side goes down and right side goes up.
Is this just a simple wiring issue? have I plugged into the wrong point on the board? The board is GT2560
Thanks in advance for any help and advice anyone can offer
GAQ
Re: Z axis motors moving in opposite direction to each other!!!
Post by GAQ »
I've heard of this problem before...
One builder had a circuit board with an incorrectly mounted socket...
It can be solved.
This post thread may help you...
https://www.geeetech.com/forum/viewtopi ... 996#p98996
Gerry
Hi,You can check if your wiring is correct.
you can refer to this:
